Hi Is it possible to use both the HereFlow Lidar and the I2C sonar at the same time?
I can currently get one or the other reading but if i enable the Lidar for the HereFlow it stops detecting the I2C sonar.
Also the address for the HereFlow works while set as 0 is this intended or does HereFlow have an address you need to set similar to the I2C sonar?
Hi, I have the same issue, when the can bus is enabled the I2C bus is disabled.
But I really don’t know if it should be like this.
Anyone who can help us with this?
yes , me too. i couldn’t get to work with the rangefinders in the i2c , when CAN enabled gps and hereflow is working.
any help? or a confirmation that is not a fault. @philip@rmackay9
