Herelink 1.1 constant freezing up
I’m trying my best to believe in the Herelink system but I’m finding it to be a complete letdown to be honest…
We have one of the first 1.0 systems and it works fine for mission planning but the video transmission is not exactly smooth and our main problem has been transmitting via hotspot to a laptop. I’ve tried multiple laptops but we always get random graying out on the video stream in mission planner. Sometimes it’s highly intermittent, other times it’s so bad to the point of un-useable.
I ordered two 1.1 systems from IRlock at the end of January. I finally got time to try them today. Installed first system, updated controller and air unit, then Solex app. Everything looks like it’s working fine but controller constantly completely freezes up. Sometimes it’ll be when you tap something, other times when it’s just sitting there streaming video. Opened the second controller, updated everything, exact same freezing, completely unreliable. I can go back to my original 1.0 unit and have zero freezing up.
Also the jog wheel on one of the new units is jacked up. It’s loose around center and does not re-center when you let off so our gimbal keeps tilting. I can max out the DZ and almost get rid of it but it’s still jacked.
I love the Cube, we probably have more than 25 of them here but this Herelink system gives me zero faith. We normally use Graupner radios, Connex video systems, and RFD900s. That has proven incredibly reliable for many years…
Anybody have ideas on the freezing up?
Brad
Strange. Is it only freezing up when you’re trying to broadcast to a laptop?
Hi Andrew,
No, it freezes up whether using the hot spot or not.
I never had a problem but mine just froze when switching from HDMI 1 to HDMI 2.
The obvious step would be to download the most recent firmware—a new version came out last week I think.
yes, please make sure you are uptodate first, then if you are still facing problems then a bugreport would help see whats going on.
make sure you download the latest version of the flasher app.
you can get it here
Have the same issue on two systems ! Both bought this month from RC innovations. Complete dissapointment. As a company we will be moving to SIYI Systems. We are done with cubepilot and their lousy support.
EDIT: here’s a video: Herelink v1.1 defective - YouTube
