Hello. Does anyone know what is abroadcasting power of the air unit? (in mW or dBm). Thanks a lot!
Just around 28db and around 650 - 680mw depending on channel.
Thanks for your info. It seems not high power enough to for long range video. At about 9-10 km the ground unit only receives at low level under 1.000 kbs, it is not enough for HD streaming.
And one more. Right antenna of the ground unit seems not work well, even when I switched positions of two these antennas! So, what is happen with this antenna?
Actualy, the left antenna of 2 dbi is one has decisive nature at long distance!
