Herelink Air Unit Module Vídeo receiver module
Hi can any one tell me what module is available to receive transmission from Herelink Air Unit Module I’m looking for only receiver video live feed from Herelink Air Unit Module thanks for all the help
You can do this with wifi hotspot/usb/usb-hdmi cable
https://docs.cubepilot.org/user-guides/herelink/herelink-user-guides/share-video-stream
Thanks for the help….that only works if I’m using the controller unit ? ….can I use the air unit with some type of receiver just to receive HD video can the air unit works with out the ground station interface unit ?
You need the controller. Our developers are working on improvements that allows you to receive signals without the controller, but there is no exact schedule.
