Herelink Air Unit to Jetson Nano via Wi-Fi: Alternatives to Ethernet Port
Is it possible to connect the Herelink Air Unit’s Wi-Fi to a Jetson Nano without using the Ethernet port? If so, what alternative methods could enable this connection?
Use an Ethernet-to-USB converter to save the Ethernet port on the Jetson.
The issue im facing is with the ethernet port of the herelink airunit it is not working is there any alternatives maybe a way to use the herelink airunit usb port and connected it to the jetson nano usb? I tried connecting them but nothing happened is there certain options i have to put on the jetson nano for this to work, or also is there another way to broadcast the wifi of the herelink airunit to the jeston nano without using the ethernet port!
