I am in the process of implementing a certain solution in which I use a combination of two air unit. Video streaming and telemetry are working fine. However, I have a question, is it possible to broadcast the Sbus signal from a PC hooked up to the GC Airunit? I have a need to control a certain device using Sbus from Herelink.
I have a need to just broadcast Sbus on the Ground unit side like the Herelink controller does. I am aware that there is no dedicated Sbus input, but I thought I would be able to broadcast it in some other way, I am using an airunit to airunit connection so I am connected to the Ground unit via ethernet.
Yes I know that SIYI has a range of such devices and I must say that I am looking more and more in their direction, especially since I have several of their products and I must say that at least they have a good responsive support. And here…
