i have a question about the combination from HereLink and Kore Carrier Board.
I want to use the J19 (12.2V) plug from the Kore Carrier Board to power the Herelink Air Unit.
Is this okay or should i use a different plug on the board?
My second question is, i am using a Tarot Landing Gear controller that need a PWM signal from the flight controller. Should i use the Aux pins on the Kore Carrier Board for that?
@Alvin Thanks for clarifying this! Can I recommend that you guys add this to the documentation on the Kore Carrier board page and/or the Airunit page. Maybe I missed it, but this is the only place where I was able to find this information. It would be good to have a note on the info about J19 that indicates it is a potential power port for the Airunit.
