Hi
Can I use an extension for the HereLink antenas on the drone? It I can, any recomendation?
thanks!
Hi
thanks!
Not if you want it to be compliant with FCC etc… but it is possible
but my question is if extend the antenna can decrease or make the signal bad.
thanks
If you wish to experiment with that you are welcome.
I cannot predict what your modifications will do, as it all depends on what you use to do this and why.
The system is designed to work as shipped.
For every connector you add, expect signal loss…
thanks, I apreciatte your help
last question, is any problem if the antenna cable goes inside a carbon fiber tube?
No issues whatsoever with that ![]()
