you need to pre rotate all your images, and then it will display correctly.
Thats sounds perfect for us. Do you have a contact that I can email to?
@Michael_Oborne
Thanks for your infomation! Finally, follow your tips got it work!
I think the doc from cubepilot website missing two keywords,
1, “compress the zip file using “store” ie no compression” you mentioned above
2, “the issue is that you have a extra folder level in the zip. when i open the zip i see a folder bootanimation. this is incorrect. i should see part0 part1 and desc.txt” you mentioned above
thank you again!
What is not clear to me is, if i do this the img i download are the latest? Has it anything to do with ground and air updates?
