Herelink Analog-stick controller is showing that it is in the center position in the “Herelink Settings” application, I have tried calibrating the joystick module and SBUS out of the Telemetry
Still, I am facing the issue.
Have you calibrate your flight controller?
You can’t say Herelink cause the issue unless something is clearly showing it was sending non-centered signal while showing it is centered.
Please post the log so that we can verify this.
