is there a way to use the Herelink controller as a windows HID device?
Would be nice for using it for SITL simulations.
I guess it’s not possible, but no harm in asking…
Tobi
Tobi
i happen to have some code that makes the herelink act as a limited xbox 360 controller. its not ready for public release though
Hi @Michael_Oborne,
hmm, I am not sure if acting as a xbox 360 controller would make it work with a Windows flight sim. Do you know if the code would make it show up as a HID device?
I’d be happy to act as a tester for any code!
yes, appears as a usb hid device and a joystick uner windows, and has been “tested” with realflight
Hey Michael Oborne.
I would like to test that out. Im currently looking for a “long range joystick” for my control station. and this could be a option for me.
one quick quistion. is it possible to connect the airunit and herelink running as a " joystick" in Qgroundcontrol?
Hi @MBVJdev1 , I would also like to test that code. Meanwhile, I found this video:
It seems that there’s definitely a way to turn rc signal into Windows HDI input if you’re willing to do a few things like solder wires to a microphone jack, or connect a receiver to an Arduino. Have a look!
I’m playing around with it now but doesn’t seem to work with the Airunit via its Sbus1 signal. but defiantly a possible solution if i can get it up and working.
@MBVJdev1 , make sure you take the correct one of the two sbus cables, I seem to remember that for some reason only one of them works…
Which route from the video are you trying?
i might be doing it wrong, the airunit is connected to my pc via a FTDI and running the Vjoy as showd in the video, and the Sbus 1 signal is set to RX. any help would be super
@MBVJdev1 , I will be looking into this over the weekend or next week and get back to you with any insights gained!
thanks alot m8 ill keep working with it to see if i finde a way around it any way
ive added the alpha build here
you need to put the herelink in dual operator mode for it to see the windows machine, and they both need to be on the same wifi, ie comms is via wifi, not usb
Hi @Michael_Oborne , are you saying the Herelink needs to be connected to the Windows machine via Wifi rather than USB cable?
That’ll be difficult in my case as my home wifi is in 2.4 GHz only, I don’t think I can use Herelink and wifi in parallel
the design goal was to be wireless.
so yes wifi for everything.
you could try usb tethering, but its 100% untested from my side
@Michael_Oborne Should the Herelink be in Main or slave mode? This is awesome. Thank you for developing and sharing this
slave. there herelink needs to send the rc data to the pc.
brief instructions are here
Do you know how to make it work via usb? we have the need for a no wifi system.
WORKING: Herelink Controller to Windows via USB
I have managed to get my herelink controller connected to my windows computer via USB and have it act as a joystick to control my Airsim PX4 simulator rendered in Unreal.
Steps to connect:
Now you can use the controller as an xbox360 emulated controller.
Good luck
