Herelink - Datasheet
Hey Cubepilot support,
I’m an engineer working at Accord Global technologies, and I wanted to know more detailed specification of your product “Herelink”.
I have found some references from your website:
“Herelink Overview - CubePilot”
In this page there is no detailed explanation, only we have an abstract level of understanding of your product.
So can you please share the Datasheet of “Herelink” product.
Thank you,
Vaishakh (Sr. system engineer)
Accord Global technologies pvt. ltd.
Bengaluru.
What specifically would you like to know?
Hi Cubepilot support,
These are my following questions regarding Herelink :
  1. Which Encoder and Decoder used in the product?
  2. What kind of Encryption technology used?
  3. What is the overall power consumption?
  4. What is the maximum data rate support?
  5. Which modulation technique is used?
  6. What is the maximum bandwidth support?
  7. Which network topology is used?
  8. Which diversity technique is used?
  9. What are the available interfaces?
Can you please answer these above questions.
Thank you!
  1. Which Encoder and Decoder used in the product? h264 gpu accelerated, h265 capable
  2. What kind of Encryption technology used? aes128ctr
  3. What is the overall power consumption? less than 4w
  4. What is the maximum data rate support? 16Mbps
  5. Which modulation technique is used? qpsk
  6. What is the maximum bandwidth support? 20mhz
  7. Which network topology is used? point to point
  8. Which diversity technique is used? MISO
  9. What are the available interfaces? ethernet, usb, serial
Thank you Cubepilot for your response.
Could you please answer some additional questions below:
  1. What is the Operational temperature range?
  2. Which Data Transmission technology used ? (such as FHSS or DHSS)
  3. What is the Maximum transmission output power ?
  4. Which encoder/decoder used at the bit level during transmission ? (For example LDPC).
  1. What is the Operational temperature range? 45 ambient, out of direct sunlight
  2. Which Data Transmission technology used ? LTE
  3. What is the Maximum transmission output power ? 23dbm
  4. Which encoder/decoder used at the bit level during transmission ? LTE
Hey Michael thanks for your answer.
Let me illustrate more about question 10.
What is the temperature range that your device will operate properly?
(Such as from -40 to +50 degree Celsius)
i cant directly answer that, as it depends on to many conditions
ie is it already on while moving to a cold environment? etc etc. if it was a single component in isolation then would be easier to answer, but as a complete system
the limits come down to the battery inside the gcs unit, and self heating.
ie
cpu max temp is 100c
RF front end is 85
PA is 90
battery 60
low temp wise, industry standards would say the min battery temp is 0c.
Hi Michael,
Can you please give more information regarding below questions:
  1. What is the Error detection and correction technique used?
  2. What is the Multiplexing technique used to send the data?
