I have been working with both a Nextvision Trip 6 and a Voxl 2 with Herelink 1.1 integrations with ethernet video streaming and I am having issues with the video streams, both have a very slow video feed of about 1 frame every 5 seconds. This is with two different controllers and air units.
The Nextvision trip 6 is a UDP stream, and the Voxl 2 is a RTSP stream. I also have used a SIYI S10 gimbal with the Ethernet stream and that one has a good feed with low latency and a high framerate.
Any ideas on what could cause the frames to stall out like this? Resolution? Bitrate?
Thanks,
Nicholas Hansen
