I was wondering what GNSS chip is installed in the Herelink Ground Unit. And if Galileo GNSS is available and how to activate/setup.
Thanks in advance.
Chip on the Herelink Controller is the ordinary GNSS module like those on smartphones
Hi Alvin,
thanks for your reply, but could you explain a bit more. All smartphones do not mount the same GNSS module (and all not support Galileo) and the most important of my last question, Herelink supports Galileo GNSS?
It is a BCM47531 inside which does not support Galileo
Thanks Alvin!
