Herelink handset QGround Control not showing battery voltage
I am using a Herelink handset with QGround Control firmware 4.4.4. I am trying to get the battery voltage to show up on the screen. I somehow stumbled on a work around but not on the first connect. The battery voltage will show dashes but no numbers. However if I open Mission Planner on the handset I can see the battery voltage. Then when I switch back to the QGround Control app the battery voltage now shows up. It is pretty annoying having to do the “dance” to get battery voltage showing since it is one of the critical piece of data I need on screen. I am using a Cube Orange and a Hexsoon EDU450 V2 as a test bed for now. I am using the power module that came with the Cube Orange and I have played with the “sensors” on the power page.
Thanks in advance for any suggestion for work around.
