I am trying to figure out how to use the joystick on Herelink as “Joystick” input in QGC.
I do not want to set it up as a radio with air module. I only want to use it as Joystick input.
In some older youtube videos the herelink shows a Joystick tab in QGC but it never apears there for me.
Is there some setting that needs to be enabled on the herelink to enable this?
i have not seen it and just created the middleware solution how to connect the game Turtle Beach Joystick to the Taranis transmitter and drive the drone from the Joystick directly. But it is the middleware hardware solution between Joystick and Taranis. Also with some middleware you could connect your Transmitter to the Ground station software or to your own software which will show all telemetry from your drone, and it is working without using any VTX and you could see on the drawn screen how your drone is flying
