I am able to use Mission Planner on the Herelink and successfully connect to an NTRIP server and get RTK functioning there. However, I like the interface of QGC better and want to use that for the primary flight view. The only problem is that if I open QGC, Mission Planner seems to shut down, and vice-versa.
I am assuming this is by design and a restriction of how they work on the Herelink, but is there any way to keep Mission Planner open in the background and still transmitting the RTK corrections? Alternatively is there any way to use an online NTRIP server for RTK on the Herelink QGC?
@Michael_Oborne I have seen you have experience with this. Do you have any suggestions? The ideal situation would be to have the NTRIP functionalilty built into QGC on the Herelink but I’m not sure if that’s possible. Please let me know if you have any suggestions.
Thanks.
