I was testing here link for a while now, and it was working normal.
Today i wanted to arm the drone and nothing happened… I was trying to do the calibration inside the mission planer but there were no stick movements, so i went into herelink setup to calibrate the sticks, and there were no inputs showing nothing was moving even after the calibration…
All cables are conected properly, and the reaciver is conected (paired). The problem is that i dont get any stick movements in the remote callibration. (hereling configuration).
Here is the video: https://youtu.be/ORUe68uHAks
I already did factory reset and update the firmware and nothing happened… Its really strange it happened out of nowhere, I was flying normaly, all worked well, and the next day that happened it sucks
Thank you for your answers!
There may be a chance you pulled the throttle stick too hard, such that a small component peeled off.
If you don’t care about voiding the warranty, you may open the housing and have a look.
If you do care, request a RMA for inspection.
