When connecting with Herelink the pairing part goes smoothly but when i hit the radio calibration it shows the error [Detected 0 radio channels. To operate PX4, you need at least 5 channels].
Herelink is connected with the gcs but the radio part does not seem to connect. the telemetry part works just fine its just the radio part that giving me trouble .Please help ASAP.
The Sbus cable from the herelink has 2 outputs the yellow and black cable s you need to connect to your FC are the ones nearest the antennae. connect these to your SBUS in on the Autopilot and make depending on which autopilot you use you may need to set a parameter to SBUS instead of RSSI
Bonjour, pareil que Gourav1997 impossible de calibrer les joysticks, erreur idem.
j ai un Herelink avec sbus 1 connecté sur sbus in sur le cube.
help!!! je galère !! merci.
