I’ve been using my Herelink without any issues for almost 6 months, but recently the signal started dropping randomly on the drone. I figured it was a firmware issue and once I preformed a firmware update my Ground unit no longer pairs with my air unit and the ground unit is no longer showing a “controller signal strength”. I even bought a second controller and the same issue is happening.
Set-up:
- Cube Orange with Kore Carrier board
- Air unit supplied by 12 V
- Antennas are 20 cm apart.
Has anyone found a solution to this?
Thank you.
