I know that hard-core RC guys complain about spring loaded throttle - yet I prefer FBWB, Cruise and Auto (flightplan) modes - and for this spring loaded throttle stick is actually preferable.
Have not done any range tests yet - probably current antenna placement needs optimization.
Antennas are in the belly - laid down on each side at the moment. Im suspecting its not most efficient way in terms of signal quality - but there is no space elsewhere for them. I may try to flip them - so that they would face towards ground (atm their backside is facing the ground).
@Pascal_Detournay do you know at which RSSI value connection is expected to drop? Today I only flew in visible range - ie max 300-400m away - and lowest RSSI value I saw was -102 (normally it was between -70 and -96. Auto transmit power was ON.
All you can remove case of the antenna and cut off needless part on PCB board. I have done and it work, now it is much smaller than stock and you can insert it easily to your fixed wing.
If you place the antenas wrong way then the video link will become very bad even in short range (under 100 m with video link - I have been through.
With video link, it seems maximum -130 dbm rssi. Max video range I have tested with my system is 8,6 km
And one more, set your herelink to CCE mode and set uplink and downlink at maximum, 20M, if i am not wrong!
