I am experiencing some problems, sometimes our Herelink Air units stops working in the middle of the flight, after some time, like 10-15 min. Our design has all the electronics inside a central shell with no cooling. I strip all the components to fit them in the smaller space possible. So I did with the HereLink AIr unit.
My guess is that the Herelink Air Unit Overheats, and that is why stops working. After 5 min or so with the drone off, everything works again.
I know but the case is big and heavy, I had to get rid of it to fit the air unit in Our UAV. I did not have the problems before, maybe the Texan summer is somehow related The center part of the drone is an aluminum shell, I am going to try to use it as heat sink.
Good to know it’s an issue - it’s now winter in the South, I fear all our craft will overheat comes summer in South Africa… We’ll have to get fans installed.
Currently our ground unit is getting super hot. Any tips?
try keep it out of direct sunlight. there is a shutdown temperature if the battery gets too hot. but out of direct sunlight this should not be an issue
Currently in EU we call it hot around 39 degree celsius temperatures and i experient some sudden shutdown of the here link controller. So not the AirUnit but the controller
No other obvious reason i can think of other then heat related.
