Hi everyone,
I have 2 Herelink kits.
One air unite installed on the drone with good pairing to “it’s” ground unit.
I tried to pair the second unit to the same air unit (I know that I can pair one ground unit to air unit at a time) it paired but once I turn off the drone it cannot pair back and I couldn’t do it manually.
I can pair easily the first ground unite back and it works just fine.
All the units (2 ground and 2 air) are updated.
I can pair the second controller to the second air unit.
I performed Factory data reset on the second controller and managed to connect it to first air unit manually twice but it never reconnected automatically after power cycle the drone.
Currently I cannot connect it manually as well.
First controller easily can be connected to both air units.
So that’s you can’t cross pairing those 2 sets of Herelink? That’s weird
Once paired, the air unit and controller will stick together until you conduct another pairing.
Normally:
A - A
B - B
If you re-pair them as
A - B
B - A
Then they will stick together until you pair them again
After rebooting, they are still
A - B
B - A
If any one is turned off, its partner won’t connect to the original partner.
A - B
B(off) - A(no connection)
B(no connection) - A(off)
