Hello everyone,
I am using the herelink system with cube orange and have encountered a new error : pre arm RC not found, i have checked the connections and as far as i know everything seems right, sbus1 is plugged into RCIN and i have flown this UAV previously with the same setup, i have checked that the wire itself is working properly and now i am stuck. Can anyone help with this?
Does the groundstation software (QGC?) on the Herelink connect to the flight controller via mavlink OK?
Yes it does, and the airunit transmits video normally too, the only problem is with the RC connection
OK, is the flight controller running Ardupilot or PX4?
If Ardupilot, you can set LOG_DISARMED,1 , run some tests, download the .bin log then upload it to a filesharing service, like dropbox or onedrive, and put the link to it here.
Maybe a photo of the wiring?
Will do and get back to you, thank you so much
Ayni sey benim cube dede var onceden dronu ayni malzemeler ucurdum ama kupe baglantigimda rc not found diyor ama kumandaya baglaniyor
