I am using a 3s LiPoly on my FW plane. My measured current was 0.68 Amps. How do you enter this value under Power ----> Measured current field . What I want to know is the unit of measurement. Is this value entered in Amps or milli Amps
Unfortunately , I am not getting the correct feedback from this calculation. I measured actual current and voltage and yet I think it may not be correct. Can you please find out from any developer, what intended measurement of unit has to be entered here . this is very important
You may need to ask on PX4 or QGC forum. As this is the setup but not hardware problem.
Also, I assume you are using current measurement compatible power module, as the power brick mini doesn’t.
Oh really… Strange Herelink QGC is requesting me to enter the current field as well Also now I get the message UAV power very low but the battery is almost full !
