Got a herelink here (another) that’s misbehaving. It’ll randomly loose video connectivity, which is fairly normal it seems…, but this one is also loosing the telemetry stream. RC remains up. I originally thought it was temperature related, but appears to not be and is just intermittent.
Whats the process to troubleshoot, or enable logging etc, before I RMA another one. Its on the non solex firmware.
Cables fine, been replaced, issue still exists. Pretty sure its a herelink issue.
HDMI is using a cable robbed from a solo, video works intermittently. I originally had a hunch it was temperature based issue, but it appears to be totally intermittent rather than anything physical.
How do I enable logging etc do troubleshoot the herelink?
Control handover between X9E/RFD900x and Herelink, not that its currently working due to SBUS on UART firmware issues, but we cant hand over between a mavlink commanded flight mode etc from herelink to a channel x sbus output commanded mode.
We are having the same issue. Sometimes the telemetry and the video stop.
To make them work again, it is sufficient to close the Qground app and then reopen, and everything work again. I don’t think it’s a message mismatch between arducopter 4.0.4 and qground control since the video is affected also (and not only the telemetry)
In this case I think QGC maybe glitched. You can test with Solex to verify if this only happens on QGC.
It may worth trying to reload firmware once again as this solve software problem in most of the times.
I have had this issue with three herelink units so far. For the first one we checked the wires, reflashed the firmware, etc. It didn’t work. After that we connected a regular telemetry radio just so we could fly (RC link smeeed stable) and we recovered telemetry when the vehicle was like 100 meters away from the herelink transmitter, the other two presented the same problem yesterday, once again we reflashed everything and checked the wires, but we couldn´t make it work (again, we have a stable RC link but no telemetry or video).
