Hi
Im driving a servo with the HL, but the servo min position is on 950, and on the HL the min I can get for a button is 1100.
There is any way to drive it to 950?
thanks
Hi
thanks
Not 100% sure, but I assume that if you set SERVOx_MIN to 950 and RCx_MIN to 1100, Ardupilot should transform your RC input to the configured output range for the servo.
Yes beciase you have assigned it to the RC pass through basically and that overrides Ardu. Ie 57 is telling the output to do what the RC says…
The output can basically only follow the input. If you Map it with Solex and Mavlink commands you could expand the range.
