Herelink RTSP Stream
I have a NextVision Trip6 connected to a 1.1 air unit over ethernet and I’m trying to access its RTSP stream via QGroundControl on the Herelink Ground Unit. I have the Trip setup with the following config.
IP: 192.168.144.23
Netmask: 255.255.0.0 (i’ve also tried 255.255.255.0)
Gateway: 192.168.144.11 (I’ve also tried 192.168.43.1 and 192.168.144.10)
I’ve also pointed the RTSP stream to many different IPs with no luck and tried a UDP stream at 11024
With any of the previously mentioned configs, I cannot connect to an RTSP stream or a UDP stream (RTSP at .144.23 or .144.11 or .144.10 and UDP on port 11024 which is the standard port on the Trip)
Any tricks I’m missing or possible solutions. Thanks in advance
Have you tried using the siyi qgc? For us that worked
try stock qgc.
ips look ok
mask should be 255.255.255.0
gateway of 11 is good as well.
