Is there a way to use the Herelink with S.BUS without UART telemetry?
It just looks like this …
Herelink is connected to a simple controller via S.BUS.
I do not need telemetry. It is a UGV the current has no cube.
(Pixhawk 2.1 has been ordered for a while … but my dealer has been pretending to be dead for a month.)
I have no data on the S.BUS. I assume that currently no control commands are released because of missing telemetry.
If it is not possible in general I do not have to search for it.
Also interested in this. With the Herelink controlling the camera/gimbal only via sBus, and C2 via L9R r/x and RFD900+.
In that configuration would it also be possible to use the FC to manage the gimbal under mission planner control? And regain manual gimbal control from the Herelink ?
I had tried it with an SBUS-> PWM converter. So first on a FrSky with a R9 receiver. After that worked, I clamped 1 to 1 on the HereLink.
The SBUS converter is a very simple device. That’s why I used it for testing. The device said that it receives no signals.
I had previously done the calibration of the gimbal. The graphic also shows movements.
My suspicion was that there might still be a release in HereLink about UART.
Because the top of the display is written … No connection. So why then send over SBUS signals, etc. So the thought.
Hence the question.
So if that works without UART, I will try again with an other SBUS / FC.
The selection is there … just not the time.
