Hi everyone,
I have a herelink station with firmware 0.2.2 and the receiver with the same firmware version. I am using it with a Pixhawk cube black. I have installed the version of Rover 3.5.2.
In the Qground radio control setup menu, after calibrating the joysticks, the throttle stays in the position shown in the screenshots.
When I raise the joystick the throttle goes up, and when I lower the joystick the throttle also goes up.
I have already tried to calibrate the joysticks from the Dial Pad menu.
Here is the param file
rover param.zip (3.7 KB)
Thank you
