Herelink v1.0 Air Unit update to v1.1 Firmware WORKING 2024
WINDOWS USERS!
  1. Assuming you have already downloaded/installed the USB Driver ( https://herelinkfw.cubepilot.org/driver.msi ) and downloaded the latest flasher_win.exe ( https://herelinkfw.cubepilot.org/flasher_win.zip ), please extract then right click on this extracted flasher_win.exe file and in the list click on ‘Add Shortcut’. Depending on what Windows version you are using you may need to click on ‘More Options’ at the bottom to see ‘Add Shortcut’.
  2. Now that you have a new Shortcut file please right click this shortcut file and select properties from the list.
  3. We need to modify the name of the flasher_win.exe file name that may look something like this:
    C:\Users\HOME\Desktop\HERELINK\flasher_win.exe
    (Under the shortcut tab)
  1. At the end of this file we need to add beta to the end of flasher_win.exe so it looks like this- flasher_win.exe beta
    (beta must be LOWERCASE or the update will NOT work) There also must be a single space in between .exe and beta
  1. Click OK at the bottom to save it.
  2. Power on your airunit. You dont need the sbus or UART cables connecred but you should have the antennas connected to the air unit.
  3. Plug a USB cable into the air unit then open the shortcut file you created above.
  4. Once the file is opened it will say Looking for Device…
  5. Now plug the other end of your USB cable thats plugged into the air unit into your PC/Laptop.
  6. Assuming your PC/Laptop is already connected to the internet by WIFI or mobile phone hotspot your beta updates will start downloading.
  7. Once all downloaded and extracted and flashed it will say press ENTER to continue. Press Enter key
  8. Your shortcut file that you opened will close. Your air unit is now updated.
  9. Disconnect power to the air unit.
  10. Power on the air unit and your Herelink controller.
  11. You will need to pair it first (In Herelink Settings) as the air unit was flashed.
  12. Once paired click on Air Unit in Herelink settings to confirm the update was successful.
  13. Check online version and see if there is a newer update.
  14. Open Mission Planner and connect wirelessly to Herelink. (Your Herelink controller should be connected to a local WIFI/ Phone hotspot connection using 5Gz. Please do NOT use Herelink controllers HOTSPOT)
  15. Go to Radio Calibration in Mission Planner and move stick around on your Herelink controller to confirm your sbus out is working.
  16. ENJOY
-Andrew
Andrew,
Thank you!!!
Because of you taking the time to write this out, my sanity has been saved :slight_smile:
It’s beyond me why the devs can’t just give all the information in one post. Especially for these issues that a lot of users are suffering with. It seems all the critical details are kept from people. When someone tells me to install the beta firmware there is normally a download labeled beta right below the standard version. I think a lot of computer programmers must secretly hate their fellow humans, I’ve worked with a bunch of them that definitely do :):melting_face:
Now if I can just get your step 18 working, I can be happy with this damn Herelink for once.
Cheers brother! :clinking_beer_mugs:
@Michael_Oborne Can you guys please pin Andrews post somewhere where people can find it easily?
Can you please advice why do we require the Air unit of a Herelink v1.0 to be updated to v1.1 . Is it mandatory or am I missing something here .
