Herelink v1.1 Joystick dead
My Herelink v1.1 was working fine as I was setting up a new Cube, then the joysticks just stopped working. It didn’t fall, I didn’t force the joysticks, they just stopped working and cannot be calibrated as they don’t move off of the center during calibration. Reset the controller multiple times and reinstalled updates. Is this a hardware issue or is there some software solution?
Hi Bryson,
Reviving an old thread but i was wondering if you got the problem fixed and how?
Unfortunately, the joysticks on my Herelink 1.1 remote unit stopped responding the same way as you described. The unit was working fine, didn’t fell no software update and all of a sudden there is no output on the RC channels. When i open the joystick settings, all stick values are centered and do not respond to the stick movements. I did a factory reset, no response, flashed the unit over USB, updated to latest via OTA/WiFi still no response.
The wheel on the left shoulder is working just fine throughout the update/reset cycle.
@philip Is there a way to troubleshoot the issue and confirm if its the joystick hardware or something else? Also, are there replacement joysticks available from Hex/Cubepilot that i can purchase and install to fix this?
Looking forward to some help please.
Amir
Hi Siddharth @sidbh Could you please tag someone who can help with this.
Much appreciated
Hi @AmirM may I know have you solved this problem? I met the same problem today and need some help, thanks a lot!
Sorry for the slow response. I have not been able to resolve this issue.
