After updating firmware using flash _win.exe the unit is unable to activate wifi which is needed for the activation process.
Any help will be appreciated
@Michael_Oborne another one for you.
do a factory reset again. would be my first action.
I have done it several times, everything in the update goes well but the wifi failure persists
is is possible you can create a bugreport on this unit
here it is
please try change the country code to EU, then back to US
Hi, I have just tried, still not working
Hi @Michael_Oborne, any other suggestions? Might I try with an older firmware version?
Hi @Michael_Oborne, Do you have any other ideas? Or should I just give up on this unit? I have several others, and I’m afraid I’ll update and have the same problem.
