Hello all,
Today I realise that herelink hw whell moving as I was lowering throttle joystick. I have already update to latest firmware and do 1 reset. The problem is still there. Can anyone has same problem? Solution for that? Its hardware or software problem. I attached photo.
Have you completed the hardware calibration yet?
Yes of course. Both joystick and Hardwheel.
Can you show a video Id like to see this, its possible the spring has come free from the clip.
I attached video from the problem.
https://drive.google.com/file/d/1wG_TYlKXVpc_catcqPDawBicsYvHicVH/view?usp=drivesdk
Hmm that seems more software to me. Very odd.
Have you tried the hardware calibrations from the phone menus ?
Thanks for your help. I just try it with no luck. After I have done more than 10 calibrations it seems the problem to appear more sparsely but Its there. If I moved the stick more than 20 times to lower throttle then the gimbal wheel is starting to move again.
Did you find a solution?
I reset to default and reflash firmware and everything works fine.
