HerePro won't boot up
Hi
I’ve been using 2 HerePro RTKs as GPS for yaw on an ongoing project of mine. I’ve been running this setup for around a month. Everything seemed to work as intended until one day. As I booted up the whole system, one of the HerePros did not seem to flash it’s LEDs or boot up. Mission planner did not recognize one of the HerePros either.
I removed both HerePros from the system and tried to power them from a lab power supply to see any indication of current consumption.
The broken one just stays at ~70mA of consumption and does not do anything. Seems like it doesn’t boot up properly? The working one does it’s boot up sequence and starts flashing LEDs as it should.
I also tried to access it with USB but nothing, device won’t be recognized by the PC. The working one got recognized by the PC right away.
Has anyone come across this issue? Is there anyway I could debug it further?
@sidbh
I had exactly the same problem. Did you find your way out of this?
