How Can I Use GPS2 Pin as primary?
Hi all. My GPS1 pin is boraken. How can i connected to GPS2. İ using HERE GPS with safety switch. İt have 8 pins but GPS2 have 6 pins. Can you help me. Thanks.
Whichever device is found on either point, it will be primary
How can i connect my here gps to pixhawk gps2 port. I have here gps 8 cable. But gps2 port 6 cable.
Adapter cable. They’re out there, but I can’t locate them right now. Thanks,
I think you can use GPS2 port.
Please check the pin definition for GPS1 and GPS2 port.
Were you able to get this done ?
Hi. Unfortunately. I couldn’t do it.
Oh…ok…may be the attached document may help …
Wiring a 10pin GPS plug to the 8pin socket on a Cube (2).zip (176.2 KB)
Thank you friend.
