I had a question which I wanted to ask. I looking to get the Herelink module, but I first wanted to know whether it fits my application or not. I wanted to transmit my live stream to the ground station which is possible using herelink but I wanted to send the same live stream to a ground station server where I can do some image processing on the Thermal Camera Video. It will be great if anyone can let me know is it possible. Thank you in advance
Thank You for your reply, but what I was looking for was that I don’t want the stream on the rtsp addresses but I want to send the video stream to a physical server which I have so that I can do some processing on the thermal camera video. Is it possible ?
I need it on a physical server because I want a companion computer to do image and video processing on the live at the ground station as the processing power required is quite high because of which I cannot mount the companion computer on the quad copter itself
