How to configure gstreamer for herelink network?
I have a banana pi zero m2 running armbain bullzeye acting as a gstreamer server that is connected to the herelink air unit via ethernet. The setup has a usb camera that encodes the video in h.264 connected to it.
I have assigned the pi a static ip address of 192.168.144.53 and gateway of 192.168.144.1
I am able to ping the pi from the herelink controller with termux and packets are sent and received.
I am using the following command to generate the gstreamer pipeline:
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-h264,width=640,height=480,framerate=30/1 ! h264parse ! rtph264pay name=pay0 pt=96 ! udpsink host=192.168.144.11 port=5600
I set the video streaming settings in QGC to: UDP h.264 Video Streaming, Port: 5600
But I cannot get the feed to come through in QGC running on the controller.
This same setup works on a local network (not herelink network) when I assign an IP address for a PC running QGC. The feed is detected and displayed in QGC.
I cannot figure out what is wrong with my setup.
Any assistance would be greatly appreciated.
Solved. Don’t use udp.
Instead of UDP, what are you using here for streaming !!
