How to fix ERROR binding UDP port: the bound address is already in use
We are facing an issue when we are trying to run our GCS on herelink RC. It says “ERROR binding UDP port: the bound address is already in use”. We tried by removing QCGS, by doing factory reset of herelink RC but still the issue remains same.
Any insight on solving this issue would be a great help.
Regards!
bind to port 14551 not 14550
Thank you! we made the default port the same advised by you and our issue is fixed.
Now we encountered another issue, video feed is not streaming on herelink it keep on showing “Waiting for video”
im going to need alot more information to really comment on this one
given your on a custom qgc, was it based off our version?
yes, its based on version 4.2.4-7
this is likerly not based on our version then, that version number is too new, please confirm your base
Issue is with connection to qgcs on herelink. Using cable to windows qgcs gets connected. But on Herelink RC its says waiting for vehicles connection. The same Herelink Rc and air unit get automatically connected with my older drone but one difference I noticed and that is I observed while connecting with old drone board (Cube orange), MAVlink link status shows connected but with the same RC MAVlink link status shows not corrected when I try on new board.However RC showing paired with air-unit.
Any solution to it?
Finally we resolved all the issues
What was required for you to resolve these issues?
We have a similar situation, where the app throws UDP bound issues upon startup.
The video comes through an RTSP link on the herelink, but we are unable to stream it to any other laptop even using the same address.
I am encountering this issue. I am trying to use the SIYI A8 with HereLink 1.1 in the SIYI QGC app as well. Both UDP ports 14550 and 14551 say already taken upon startup. Once I get the notification to clear, I still only see a “Waiting for Video” where I’d expect to see my video stream. Can someone please help walk me through this?
@Michael_Oborne Can I ask how to do this? I’ve been able to set up a Comm link in QGC on the herelink and bound to port 14551 that starts when I start QGC. The problem is that I think QGC is still trying to connect to 14550 because I still get this binding error on startup, even though QGC is able to connect to my drone. Is there a way to force QGC to stop trying to connect via 14550? Thanks in advance.
hey @Developer_Casca You can try this
  • Check for Conflicts
  • Change the Port
  • Firmware Update
    Hope this will help you
I currently have the same problem. But if I add a comlink for port 14451 I am able to receive a stream. However, I can’t seem to forward the stream with MAVLINK Forwarding in qgroundcontrol v4.4.2 and v4.4.3 for the HereLink. Any advice?
I am also facing this issue. I am trying to use the Skydroid MIPI Camera with Skydroid H16 in the QGC app. We are facing an issue when we are trying to run our GCS on Skydroid H16. It says “ERROR binding UDP port: the bound address is already in use”.And when i connect to UDP port I am getting the telemetry data but waiting for Video for confirmation whether i am getting feed or not i went to H16 tools app where i can see the feed in view camera feed. But it is not coming in QGC
