How to Setup a Skid Steering on Mission Planner and Herelink by only using one joystick?
Hello, I’m trying to setup a skid steering rover and my transmitter is herelink.
Suppose I only want to use one joystick for the rover’s skid steering (throttle left and throttle right). How can I configure this one?
These are the parameters that I have set in Mission Planner.
Servo1_Function: 73
Servo3_Function: 74
PILOT_STEER_TYPE: 0
Are there any configuration that I missed aside from these? Thanks
have you solved the problem because i have a similar issue?
@Melon_Streams Have you solved the problem because I have a similar one but need it for a rover
and @sam_tech .
Sorry it took a while.
You first configure the mission planner. Try to find out how to set it into a skid steering. Sometimes even if you have already set it to skid steer, it wont have a skid steer unless you have the autopilot restarted/rebooted.
then if it’s already skid steer, try to find the channels in herelink. as you know there are two joysticks, each with two channels. read it on mission planner and see which channels uses the forward and rotate. then combine them together in one joystick.
