Integration of NRA24 with Cube Orange+
Hello everyone,
I want to use Nanoradar NRA24 as a rangefinder to follow terrain with my cube orange+
I do follow the param settings provided in DOcumentation but still its not working and gives error
Rangefinder1 missing.
I will request if possible please provide detail info on this topic
Is this the documentation you followed? Nanoradar NRA 24 β€” Rover documentation
Can you share logs and parameters? Also some images of the setup.
Yes.
RNGFND1_RECV_ID
This last parameter was missing in my full parameter list.
But i dont think it will cause an issue
Refresh or reboot the flight controller to get the parameter.
I did but still it is not showing
I did but still, it is not showing
@Aniket download dronecan_gui_tool, connect it to Cube, and open Monitor window, check if you are receiving packets there. Also share your parameter file from the autopilot.
Finally, my issue was resolved.
After discussing with the manufacturer, they confirmed that it already has ardupilot compatible firmware with UART connectivity.
I completed the wiring per the UART and plugged in the Telem2 port.
set the following parameters to get readings from nra24
serial2_baud =115
Serrial2_Protocol =9
Rngfnd1_type =11
Rngfnd1_orient =25
