Hi everyone, I’m building a drone that uses a herelink telemetry and and an A40 Pro camera from Viewpro. The cemera is connected to the herelink air unit through the ethernet port. So far I was able to get a video input in the controller’s QGC, but I wasn’t abe to get one in Mission planner. I also need some help with the video steaming from the controller to laptop using this setup. I apologize if my question is incomplete, I’m still new with all these things. Any help is appreceated.
Here is a diagram of my setup if it helps
How did you get the video input in QGC. I am trying the same thing and have a camera connected to the ethernet port of the airunit but am getting absolutely nothing on the herelink or QGC or mission planner.
Did you ever get an answer to this? I am having the same issue
Hey @garnerlanier
yeah it kinda works now. set the ip of your camera in the range of 192.168.144.0/24 and then use an rtsp (whatever that protocol is called ) link for your QGC. For me the video does not show in QGC , but i am using another app called onvier that can also discover ONVIF cameras which mine could do and the video showed up on that .
