Hello Team Cubepilot,
I am facing some issue with recently ordered Cube Orange Plus (Reddish Orange Metallic finished one)
After I flash PX4 v1.14.3 firmware some parameters are missing
Missing parameters are;
PWM_MAIN_TIM0
PWM_MAIN_TIM1
PWM_MAIN_TIM2
Without these parameters I couldn’t use the those 8 numbers of MAIN PWM PINS of Cube orange plus
I connected the servo to one of the main pwm pins and tried to move using QGC from Actuators page in Vehicle setup screen, no movement of the servos (Even I gave power to those PWM OUTPUT pins by using external BEC power source)
But when I use my older three months back ordered Cube Orange plus,
non of the parameters missing by flashing the same firmware (px4 v1.14.3)
Not only this issue, I couldn’t able to subscribe to MAVSDK server
But order three months back ordered Cube Orange plus has no problem in this also.
This seems weird right?
The serial number of the Cube Orange plus which causing issue is;
CubeOrangePlus 0034003E 32335102 37343433
While I flash the px4 v1.14.3 from Linux terminal I got this below details;
board id: 1063
bootloader version: 5
sn: 0034003e3233510237343433
chip: 20036450
family: b’STM32H743/753/750’
revision: b’V’
flash: 1966080 bytes
windowed mode: False
Could you guys please check this serial number is CubePilot’s original authorized product or not…
and please give a solution for this issue.
Moreover, could you please let me know, Is there any hardware-wise changes in Cube Orange plus in recent days???
