The Kore board layout is optimized for quad and octa-quad configurations. There are 2x outputs at each corner.
That means that in order to setup a hex configuration, you will have to use 1x of those signal pins at each corner, then 2x more of any that are convenient for your wiring. Its a bit clumsy, yes, since there are no signal pins on the sides (only the corners).
You will have to map the outputs to the correct motor signal in mission planner (you can map any output to any motor signal, btw)
Thats Hexa X… i need Hexa + …the photos are gone.
But in MP once you start mapping it shows every kind of multi rotor config.
Just needed to know the motor number sequence.
Problem solved.
