Does anyone have a spec for the length of the M2.5 screws when using the Kore carrier?
I know that the standard carrier uses M2.5x8mm, but I suspect for the Kore they would be a bit shorter.
I have an earlier board from Spektreworks and it came with the correct screws.
Hi David,
Could you measure one for me?
8mm is fine.
M2.5 x 0.45mm pitch?
Yes, standard metric M2.5 stainless steel (non magnetic)
Just an update to any who may find this thread, as I have not updated it in a while. I did eventually get screws that fit after speaking with a friend and fellow cube owner. They are M1.6, roughly 16mm thread length
