Moving forward with the build, so more questions. Looking at using the 12vdc LED connectors in the corners. These are three pin connections so wondering if they supply a signal for driving a multicolor LED circuit? If not does anyone know of a good flasher circuit that would meet the FAA requirements for night flight?
If you look closely, the NAV pins only contains +ve and -ve.
If you use the MAINx ports, you can try external LEDs such as ProfiLED and script it yourself.
