Large x8 went crazy after sudden pitch
Drone x8 went crazy with violent pitching more it did worse it got. Couldn’t control it. It did this after a sudden pitch from myself. Can you please look at the log and tell me what you see? I’m to pissed off to look at it right now. I THINK I know what the problem is but I want/NEED everyone’s help. PLEASE. this thing has kicked my ass!
Everyone who builds knows that ever once in awhile you have that 1 build that kicks your butt. This is mine lol.
Can you list the specifications please - the reason I ask is because the X8 seems overpowered and it will be interesting and possibly quite relevant to understand the overall picture and purpose.
The motor outputs are frequently hitting minimum and the hover thrust is also very near to minimum motor output.
When you give the copter stick inputs some motors hit minimums and there’s no where else to go.
You will need to add some dummy payload.
What specifications do you need? Frame size , motors, etc?
OMG… would a cube on a carrier board with only 2 screws in cause this? I ask because I took plugged into my PC and I noticed that Cube seemed not as sturdy. So I took it off and they are only 2 screws holding the cube to the carrier board! Not sure why but yeah 2 screws.
Appears to be mechanical. You got a brutal vibe arround 90 when the problem started. There is a chance that the missing screws had to do something with it. But not much chsance. I had similar issue. The this is with cube products is that the quality fluctuating so much.
What can I do to fix it? Any suggestions?
