hello all
I want to use 5 of this Garmin Lidar lite V3 like, 4 for collision avoidance, and 1 for soft landing, is possible with pixhawk cube? or need to have another board ? if yes I need the how to. thank you in advance
hello all
You may check the set up from ardupilot wiki
https://ardupilot.org/copter/docs/common-rangefinder-lidarlite.html
but I’m not sure if it will work for collision avoidance.
If you need more i2c connectors, you can use the i2c extender board
