Mauch 090 replacement
Hi I’d like to ask you guys for a good replacement for the Mauch 090 12V bec that i pan to use for powering the herelink air module.
This bec is in back order in a lot of resellers, and in general I’m seeing a lot of accessories for the cube autopilot going to no stock, is happening something with the cube? Is it going to be taken out of the market?
Hello @Andreas_Diaz
It is due to the semiconductors crisis… it is happening to lots of companies around the world.
About your question, I always used the Castle Creations CC BEC 2.0 to power herelinks, it is a good option.
Thanks buddy! Will buy it then
We have frequently used the Turnigy Multistar Twin Output 5/10 Amp (6-50V) SBEC for Lipoly - has worked well
