depends on what you are after
for mavlink, its broadcast traffic on port 14550 or 14551
for video after enabling the hotspot its
rtsp://192.168.43.1:8554/fpv_stream
im not sure if you plan would work, but the ip the herelink controller gets is assigned by your router. so i cant answer any ip settings you have.
It was my understanding that you specify the target IP address of the UDP stream at the server (in this case: herelink)
From what I can tell, the client (in this case: MP running on a laptop) cannot specify the source of the UDP stream it can only listen.
This may be getting into feature request territory, but with both Mavproxy and mission planner, you can forward mavproxy control to a Target IP on the same network.
As far as I has been able to accomplish this seems to only be possible when the here link hotspot access point is being used. It cannot share across an existing network it is attached to.
I’m hoping somebody can Assist I have Herelink an RTK gps an Ground Station and are unable to connect Herelink controller to my GCS on my pc. I am able to connect Herelink controller to the pc on WiFi hotspot but when I do UDC connect on GCS on pc to Herelink it doesn’t connect also I have port open on Herelink as well.
